hyperlites turn signal wiring for 2016 R1200R
I just bought a 2016 R1200R and am working on conspicuity. I purchased a set of 3way hyperlites, running light, brake light and turn signals. I've connected the running and brake lights, which are working as intended. I also connected the left turn signal (yellow) wire from the left Hyperlite module with the blue CANbus turn signal wire that appears to channel toward the left turn signal, but I can't find a corresponding CANbus wire for the right turn signal. I checked the color of the front right turn signal, which is also blue, but I can't find another blue wire in the rear for the right turn signal. Maybe a dumb question, but does the CANbus blue signal wire that I used to connect the left turn signal wire from the left Hyperlite light module also control the functioning of the right Hyperlite module if I connected its yellow wire to the same CANbus wire? Any advice would be appreciated. Thanks!
