scooterboy
Let's go
Are all GPS's about the same or are some better than others?
Hi scooterboy, Welcome to the forums. Over in the Gear section of the forum you can do a search. I've set up a good example of how to search in the welcome to gear section. The key words would be gps, routing and sat/nav. There are three real good threads that should be of help. I'll move this thread over to gear to get you started, GaryAre all GPS's about the same or are some better than others?
No, they are not all the same. It depends how you want to use the device.
Check out RamMounts website for that.
