dancogan
Some good stuff, I see. Does the Zumo also have choices for calculating routes, based upon preferences of types of roads (i.e: avoid highways, or toll roads, etc.) or based upon whether to choose minor, medium or major roads?One of the biggest differences is that the Zumo touch screen is much more sensitive and the on screen buttons are larger. This makes using the touch screen much easier with gloves on. The Zumo also has an internal battery. My previous 2610 was connected to a switched power source on the bike. Anytime I turned off the ignition, such as when getting gas, the GPS would also shut off. This meant waiting for it to boot up a lot. The Zumo doesn't shut off right away, instead you get a prompt asking you if you want it to stay on. You get 30 seconds to answer "Yes" or it shuts off.
