First of all I don't know what model of bike you are referring to. However I don't recall ever seeing a shift lever extender offered for any oil head. Sliding something over the existing shaft would of course make it larger in diameter. It would then require you to angle your foot farther downward to get under it. If you need the longer shaft I can only assume you have a bigger foot and angling farther downward seems like it may be fairly ackward. Good luck, maybe someone makes an entire assembly that will fill your needs.
I tried one for a while - didn't like it, with the larger outside diameter and extra length, it actually got in the way. My rides often require quick and frequent shifting, and this (in my opinion) is more of an "easy tourer" accessory.
