B
bmwrusso
I am trying ot learn as fast as i can. I see that alot fo the parts for these bikes are interchangable. so my question is what is the best front end option i have for a dual disc snowflake front wheel? I was hoping to get the forks and everything in a recent auction but did not know that they went for so much so i was outbid. so now i have the wheel and ATE calipers and only see front forks with single discs available. should i bail on the ate and go with a brembo setup? is either more available? I have a clean slate to start with so i have to build from the ground up so i can go in any direction possible but would like a dual disc set-up.
any suggestions? also I was considering having a set of wire wheels with hoops restrung with 17" rims so i could run tires I am used to.
