bicyclenut
Member
Was having problems shifting at end of trip back from Denver to Chicago, was acting like linkage was stiff or needed lubricated and had to move lever back into middle "neutral" position to get to downshift 3-2, 2-1 and pedal was staying higher up in gear above 3. After trip sprayed some lube and seemed better but after sitting a week stated acting up again and when I went to look, I found the mount for linkage to frame was cracked and loose.
It's hard to tell but from parts fiche and looking at area, this seems to be part of main rear frame so only option may be to weld this mount back, hopefully can be done without major disassembly. Anyone seen this of had to fix this?
