BeemerMike
Republic of Texas
RBOB regular gasoline to be blended with alcohol ships as 83.7 octane and is sold as 87 octane after the alcohol is added. So the alcohol does have a higher octane number, but doesn't mean it is nearly as efficient as gasoline
Sounds about right. Ethanol is an octane booster (higher octane rating - about 113 - compared to the base gasoline), BUT ethanol has LESS energy than the gasoline, so when you blend it in the result is LESS energy per unit volume, and therefore less mpg.
