ANDYVH
I agree with most of the posts above, especially with Paul Glaves. I'm also an MSF instructor and have used my 94 RS for ERC classes with no detriment to the dry clutch. I too, hold the clutch in, and stay in gear, at a stop until I know fairly certain that nothing is happening behind that may need me to take off quickly.
I keep my clutch adjusted exactly to spec (I feel it does make a big difference), and check it a few times during my typical 10,000 mile riding season. I also make sure my clutch splines are clean and lubed with the tacky grease recommended by BMW. My RS has 140,000 miles on it, now on the 2nd clutch assembly, that I installed myself. It has great light feel to it with good lever travel. I replaced the original clutch cable at 115,000 not because I had to, I just did it to avoid a potential roadside issue.
I don't quite agree that a wet multi-plate clutch would be more reliable. A wet clutch requires a lot more friction surface to transmit the engine power, so you have multiple friction plates. But a wet clutch, again because of the multiple plates does tend to have easier/better feel and takeup, and a wider friction zone than a single plate dry clutch. Learn to make quick efficient shifts (each shift should take no more total time than a finger snap). And once the bike is moving, you really only need maybe 1/3 of the clutch lever travel to make an up or down shift. Preload the shift lever to take up the slack in the shifter, in prep for the shifts. In fact, less clutch lever travel is better than squeezing the lever to the grip every time.
