jimwjarmour
jimmy armour
Hi Guys hope all are well, just installed an almost new (to me) dyna 111 ign to replace my 25 year old unit every thing went alright until I found a ghost image of the F mark at full advance ,with the lightened flywheel I dont have the other markings only full advance dot painted white , tried to adjust by moving one of the pick ups, I see a full solid dot and above it a dull ghost image, I wonder is it the strobe I am useing it runs off the bike battery, I have set the ghost dot above the F mark and the good one just under the difference isnt as big as the timing hole there for less than 3 degrees ,how do you adjust for double dot timing? and does it show as two solid dots or is there a ghost dot like mine ?thanks in advance Jimmy
