Dellorto Carb Stuck Inlet Seat
swall
Member
Wanted to get the R90S out for a ride this year and found that the inlet seat on the left side Dellorto was leaking. Ordered one--they come as a set, with needle and screw-in seat. The OEM seat is stuck. It will not some loose using a 1/4" drive 9mm six point socket. I only tried this with the screw handle type driver, not a ratchet. I'm pretty sure any efforts with a ratchet will result in a twist-off. I am soaking it with Kroil while I contemplate options, like maybe a heat/freeze cycle. Oh-- the new needle will not interchange with the old seat, as the new needle is hex cross section vs square cross section for the OEM and is too big to fit.
Sounds like yr having a fun Saturday! I was until it got hot enough to bake bread in the garage. :)
Inside the carb, varnish makes things stick. Acetone or carb cleaner will dissolve varnish. Dunno if Kroil will work on it.
A nut driver won't apply enough force unless you're a gorilla. It is safe to use a ratchet but of course you cannot honk on it until your veins bulge or the brass will torque off.
After a 3 day Kroil soak, it came loose just a bit ago. New seat and needle installed, leak tested and we are ready for fire up.
