Concerns with new wet heads
erkj79
John Erkan
Now that I have accumulated 5800 wonderful miles on my 2014RT, I dropped it off at the dealer for the 6k mile maintenance check. In addition to the normal maintenance check for changing fluids, including break fluid flush, I had them take a look at the gear shift assist device, which is mostly inoperable and complained of a slight wiff of burning oil. after doing the post mortem, they had to order tools to remove the engine to change out a leaking engine to transmission gasket and they have to order a new gear shift assist mechanism. Anyone else seeing these type of failures? they are covered by warranty but I am beginning to wonder. The dealer did not even have the tools on hand to remove the engine...
I wouldn't be too worried. Seems to have happened at a time when you wouldn't be riding. It's under warranty. As for the "tools" statement, could be just a generic deal.......Meaning, it's easier to say that then say "we don't have the special tool that installs the inverted clip". The fact they had to order a tool for the job indicates that they haven't run into this before.........Meaning, whatever it is, it's not very "common".
Mine just turned 14k miles and has only had a weeping fork seal early on which was quickly changed. One set of tires 2k miles ago. Zero problems and that bike is not babied.
I've had a few issues in my first 14k. Nothing to have me give up the bike.
Sent from my KFSAWA using Tapatalk
It is aways thrilling when the dealership says we need to order new tools to remove the motor. I would say "You got to be shi##ing me.".
I'm curious about the "leaking engine to transmission gasket" on a Wethead, since it's all in the same case. Maybe something got confused in translation from mechanic>service desk>customer, but I'd be interested in knowing which parts actually get replaced.
My 15 RT has been great, no issues other than broken tabs on front fairing(poor design, bmw is aware of this problem)
First BMW I haven't had to rebuild the seatšŸ‘šŸ‘
I have a "wallowing" or "oscillating" issue with mine. So far the dealer has checked the tires and air pressure, alignment, replaced the leaking rear shock, and recently found a load leveling sensor unplugged (this was found during a software update), but the issue is still there. Now the service mgr is telling me it is the driveshaft, he implied I'm not use to riding a bike with a driveshaft, I told him this is my 5th BMW plus I've had an Honda ST1100 and a Shadow plus an FJR, he says Oh! I'll try another dealer, probably won't get treated as if I bought it there, and see if they have any ideas.
Best bike I have ever owned! Just shy of 14k miles and have only had regular maintenance (600,6000,12,000) and a new set of tires. And I ride this pretty hard. Even ride gravel and once off road in newly rained on mud and gravel but I stood on the pegs then. lol
Just turned 19K on my RT, ride it HARD, no issues... it's the most complete motorcycle I have ever owned.
got the bike back today after a long wait at the dealer. Gear shift assist now works perfect. I love it and all the oil leaks were fixed to perfection. tech stated that previous owner was a tad over zealous with a pressure washer and got it too close to the engine.
Nice that you are all set :thumb Nice that you followed up as well :thumb
It'a amazing how much damage can be done with a pressure washer. It used to be a real problem with 2-stroke dirt bikes.
