What is your preferred method of tire inflation in that circumstance? Old school CO2 cartridges or one of these newer compact air compressors?
I am trying to make this decision also. Does CO2 leak out of the tire any faster than air? Seems I read that somewhere or maybe dreamed it - not sure which.
his CO2 cartridges leaked while trying to fill his tire.
Air compressor is more reliable and gives you a 2nd chance. I stopped to help a guy once, we found and plugged the hole, and hooked up mu Slime pump, it seemed slow to build pressure so we started looking and found a 2nd hole!!! After plugging that it pumped up normally. If I only had co2, he would have been out of luck as it would have all leaked out while plugging the 2nd hole.
Moto pumps makes some great small pumps that take up no more room than co2.
http://motopumps.com/
You don't get much tire inflation from a Co2 cartridge. I had a flat, made the repair, and injected my 4 cartridges- it equated to 20 lbs or less of air. To really, seriously inflate a tire that needs 40 lbs of air... well, one poster above mentioned he carries 10 cartridges.
Compressor.
Stop n Go has a compressor that uses motor power- remove a spark plug, insert compressor attachment, and pump up your tire.
http://www.stopngo.com/engine-powered-air-pump-for-motorcycles-5-ft-hose-with-quick-release-lever/
A friend of mine has one of these, and I remember being VERY impressed with it. He did say "it's expensive".... It's THE most expensive option, almost without doubt. BUT.
http://www.stopngo.com/cycle-pump-adventure-model-works-on-cars-and-small-trucks-too/
Voice of experiments, as my friend Ozzie would say
