Clutch handlebar assembly
motodan
Active member
This is on a 2008 R12RT. Want to rotate clutch/switch assembly on handlebar, assume pinch bolt head is inside switch housing. If that is the case, are there just two screws to remove when splitting housing?
155 views...no input, let me try this again. Has anyone ever rotated (or removed) the clutch side gear switch on a 2005 to 2009 R1200RT? If so, how did you loosen the assembly to rotate it? Trying to get clutch lever adjusted upward.
I was going to try and recall the locations, and actually did one yesterday.
One small Phillips self tapping screw in the mirror hole well, one silver Phillips oval head under pod near blinker button and the out in the open one on the front
May have to wiggle it to allow it to come apart and the bar clamp is obvious at that point
Thank you...no doubt, silver one is the culprit here. To the garage I go.
