Howdy..looking for information [as usual..],
My owner's manual says to inspect the left side of the rear caliper and if the brake disc is visible in either of the two holes [I assume the "plugs" you see are brake pads] then the pads must be replaced..
Here is my question: 735 miles on '07 R1200GS Adventure...the forward "hole" shows the pad recessed in the hole about 1/4" while the rear "hole" has the pad flush with the surface of the caliper...what gives? Why the apparent differential wear, if that is what it is? Any with new GSAs see the same situation on your bikes?
Thanks...so much to learn! Subtle but important details!
__________________
__________________
