While doing this I really noticed alot of oil around the final drive. I must have a leak somewhere there.
I had picked up used Ohlins front and rear shocks from Parts Haus a while back, and thought I would get them rebuilt. Unfortunately the rebuild hasn't been in the budget. I expect I'll require a different spring.
The front one has an obvious leak while the rear looks good. The rear is the one I really need, so I went ahead and swapped out just the rear shock today.
I have not adjusted the preload yet. Not exactly sure how to do that, or if it's absolutely necessary. I figure I'll put a twist or two on the adjuster and take it for a spin and see how it handles bumps ...
