Excellent point! FWIW, my Cardo Freedom 4+ has never run out of charge while on 18hr rides with streaming music most of the time. Same as my original very old Cardo's.Just remember if you go to bluetooth headphones to have another device that needs charging. Plug phones makes ones that are combo ear plugs. Personally I stick to wired ones to eliminate more things to charge.
No need to worry about charging and plugging in earphones at the same time. You can plug both in at once.This point is well taken. With my phone attached to the bike, I didn't want to be tethered to my bike via the short cord on the earbuds. Plus, with the headset plug gone from most phones I would have to choose between the USB charging cable and earbuds.
I use Cardo devices and Splugs (wired ear buds.) Any wired ear bud would work, but most wouldn't be as small and comfortable as Splugs in a helmet. I have never installed any speakers in my current helmet, due to having too much road noise with a number of past speakers, now just plug my Splugs into the Cardo device, which has compatible plugs. Then, I use Cardo device as the hub for all other Bluetooth devices (GPS, phone, etc.) I have an R1200GS. My riding buddy with an RT, also uses Splugs, but he has a more complicated and troublesome connection that uses the bike's Bluetooth as central (because the RT has satellite radio, etc.) He has trouble with volume from the various connected devices.
Obviously a custom, professionally made ear bud would be optimal, but the Splugs work well enough. I tried some other cheaper ear buds but they were not as good. Splugs, at around $100, are ridiculously overpriced, but they work. That's the American way, supply and demand, sell something for as much as people are willing to pay for it. I have had a couple sets. The wires break after a while.
I used the Shure 425's. They do sound great but the wire that wraps around the ears eventually broke from daily usage. Luckily, you can buy replacement wires as they detach from the speakers and those wore out too.I also use the Cardo system with wired earbuds, usually vintage Etomotic ER 6s or Shure 425s. Been very pleased with that setup. Either set of earbuds cut out enough outside noise I can set the volume while stopped and leave it alone at speed. Also use the 425s when mowing and could probably work as shooting hearing protection.
Nope, mine is mounted. But I do carry an InReach in my pocket. That stays activated all year as I go hiking in no cell service Appalachians quite often.Also, y'all carry your phone in your pocket in the event you go off and the bike is a ways from you and you're injured and need to call someone, right?
