For setting valve clearances, you obviously have the valve covers off. With the transmission in top gear, turn the rear wheel until you see the intake valve open then close. You are beginning the compression stroke on that side. Sit by the bike and use your hand to lightly bump the engine around until you see the various marks. In most cases, the OT mark is not the OT letters but the line next to it. Generally there is some movement forward/backward around this point that does not move the valves at all...kind of a dead zone. You could set the valve clearances anywhere in this small region.
