M
MARTDNC
Hi guys,
I'm a newbee with a '05 Dakar; I think I need a new chain; the bike has 18K on it and I'm guessing that it is the original chain. The problem is that I can not adjust the chain as per the manual. I put it on the center stand and then rotate the wheel until the chain is at it's tightest, then adjust the chain. But, after making the adjustment as per the spec's, it is so loose that it slaps. If I adjust the chain when after rotating the wheel until the chain is at it's loosest position, then it binds when I rotate the wheel. Is this trying to tell me that it has stretched to the point were it must be replaced? Do I need to have the sprockets replaced at the same time?
