bike goes black
kthflieger
Need some advice- 2011 R1200Rt - had a great ride, parked the bike - all was good. Came out the next morning to start the bike and the following happened: turned the key and everything lit up and self tested. As soon as I hit the start button, heard what sounded like 2 solenoid clicks and the entire bike went black. Let it sit a while - turned on the key, hit the start button....same thing...back to black. Put the bike on the charger in case the 6 mo old battery had somehow gone bad. 24 hours later tried it again...everything lit up. Hit the starter - went black......
any ideas? thanks:scratch
You have a sealed battery and you just broke one of the connectors between the cells. With minimal load the battery shows OK voltage but as soon as you impose the starter load you have nothing.
As soon as you replace the useless battery with a new one everything will be just fine.
I had the same thing happen on my ‘11 GSA. Pushed the starter and heard a pop then black! 1 year old name brand...it happens!
