In reading the owner's manual for the new RT, it states that you cannot use non-BMW battery chargers connected to the accessory socket. I've always used a Battery Tender Junior for my old RT. The dealer installed a cable directly to the battery so that his customers can use the Battery Tender w/o buying an expensive BMW charger. The owners manual also says that if you're charging the battery, it should be disconnected from the bike. Dealer says it's not a problem with a trickle charger. Any thoughts?
