2001 R1150GS, not servo model.
After bleeding from ABS module under the tank and later from calipers, my ABS has ceased to exist.
No ABS lights when ignition turned on but relay seems to clicking normally. All fuses intact.
No ABS engaging when slamming on brakes.
Tried ABS reset procedure. Tried disconnecting and reconnecting battery.
Replaced ABS relay. Nothing. Saw some rubber crud while bleeding rear caliper.
Replaced rear brake line.
Brakes function but no ABS.
Is not time to shop for a new ABS pump/module?
Suggestions?
Suggestions?
