I’m in the process of a couple of fixes on my ’98 R1100RT; one of which is replacing original external fuel hoses. During the course of removing fuel hoses (and attempting to install quick disconnects, an idea I’ve now abandoned), I believe I did something to cause a sticky throttle. I had a nice, smooth function when I started; not so now.
There’s a good possibility I may have damaged the cable housing on the right side while I was struggling with fuel hose hose removal and futzing with the QDs. It seemed like the new hoses were putting a lot of pressure on the loop of throttle cable at the top of the butterfly housing. I didn’t leave them on long enough to apply zip ties to the hoses to relieve the pressure. I just wasn’t satisfied with the routing compared to the tidy original bent hoses I removed.
The butterfly mechanisms on right and left sides function freely but the throttle is hard to roll on and is slow to return after release. The end of the cable housing seems like it’s seated properly at the top of the butterfly unit housing.
What’s your diagnosis as to the cause of sticky throttle and what’s the recommended solution?
If the solution involves replacing the cables, I assume I’ll also need a throttle body synch. It probably makes sense to replace all the cables anyway as mileage is 66.3k.
If anyone has pics of quick disconnects installed on an 1100RT, please post. The old hoses had bends in them right where the quick disconnects would go and it just didn’t seem like I could place them without kinking the new hose or getting the new hoses too close to the right cylinder head and still out of the way of other parts. Pre-formed hoses from BMW are pricey ($65-$75 each).
Thanks all!
Thanks all!
