Hello,
I've replaced the clutch "O" ring and output shaft oil seal on a K100 and a K1100. The K100 and K1100 both had what BMW calls a STOP DISK that fits on the clutch housing. I'm now replacing the clutch oil ring and shaft seal on a '88 K75S. When I removed the clutch housing there was not a stop disk. The MAX parts fiche clutch diagram shows the stop disk as #10 but the parts description doesn't list it. So, my question is, is the '88 K75S supposed to have a stop disk and if so how do you determine what thickness to use?
Regards,
Richard in Commerce Township, MI
Regards,
