To repair or replace the cooling fan motor?
I've narrowed down the new "noise" on my 85 K100 RT to the cooling fan.
I would describe it as a rattly vibration or squeal, but I'm not sure that truly describes the sound. I've attempted to share a video of the sound so that you can judge for yourself.
The noise seems to kick in when the fan is starting up and then intermittently while the fan is running.
I've checked the area to make sure the blade is not rubbing against anything (hoses, wires, debris, etc).
The motor turns easily by hand and will generate a bit of a rattle with the initial push.
I would credit that sound to the the small amount of free-play between the fan blade and the motor shaft.
The nice part of the riding season in Minnesota is relatively short, so I'd prefer to minimize the time spent down for maintenance.
It takes a bit of work to get the fan assembly removed so I'd like the insight of experience before I get started.
What are the most likely causes of this sound and is it an easy repair?
If the best approach is to replace the motor, does anyone have instructions or helpful hints on removing the fan blade and rear plastic cup from the old motor and reinstalling them on a replacement?
http://www.beemerboneyard.com/kfanmtr0427.html
http://www.euromotoelectrics.com/BMW-Motor-Radiator-Fan-K-models-1983-1995-p/fan-k427m.htm
Thanks in advance.
Monte
85 K100RT
Thanks in advance.
Monte
85 K100RT
