Updated After Repair: Rode to the Billings WY rally and back to Phila. without incident, changed oil (hot) and found a sheared rivet in the pan.
It was a great and problem less trip of 6,500 miles. I had been told that 1985 models have only 6 rivets in the "bull" "absorber" "output shaft" gear. Some fail by 120K mi.
I'm buying replacement and upgrade parts and will take off the intermediate housing again this year (starter sprag in the spring) and drop the bottom case section and output shaft. My list of "better do while you have it apart" includes rear main seal, both o=rings on each injector, Trans. input seal, clutch pivot brg. and boot, spline lubes, change the oil and filter, lower rad. hoses, thermostat, and it's growing.
I've been advised to finally get a lift and now have a big red H. Freight one from craigslist with a modified front tire "ramp." The center stand now misses the drop out rear wheel panel and the ft. tire sits right in the clamp when it rolls back onto the center stand.
