Thanks, will give it a shot this weekend.Any time I have changed a master cylinder I have bench bled them. It was usually a line(s) from the port into the reservoir beneath the fluid level and work the piston until there were no bubbles.
This insured the internals were air free. On an older M/C it can, or may, allow a clue to the efficiency of the piston stroke via the feel of piston resistance.
32 72 2 310 786 | CYLINDER WITH PISTON - D=13MM | 0.39 | 1 | $250.00 |
Apple Hydraulics will rebuild it for you, but I don't know that it would be cost effective. For the MCs that cost $400+, it sure would be. I will be sending a few R1100 MCs to them.
Thanks, Anton. It's frozen all the way in. I worked and worked on the corrosion but seems like there's zero give/movement on it. And seems like it's a breakeven proposition to buy vs rebuild.Pretty sure that is simply a part that EME buys from BMW. BMW cracked down on Brembo for selling to the aftermarket, so it's all probably going through BMW now.
If you scrape the residue away from around the piston, you will create a free path for it to come out. Push it all the way in and then clean around the opening.
