I agree with all of you. I think the problem is going to be finding the parts. The Old "Trails End BMW" is selling Enfields, The new one is with the harley shop.
I'll look on line today.
Bob
very glad to see you are marking everything well so the clutch goes back together balanced and the timing mrks line up, two cents worth, put something more positive to block the crank(long board and straps(not bungies!) its one of those very oh s**t deals...
Any body think I'm messing up?
I think you'll find out when you bolt everything back up. If you bolt up the flywheel and at some point in the tightening process, the engine doesn't turn anymore, then the thrust washers came off their pegs. At that point, you have to figure out how to get them back on. IIRC, one can come back in through one of the case openings, after completing removing the top end.
