M
mrhtbd
Finally fixed the electric problem (amongst other things). But first I learned my lesson when I took it for a ride with a bad starter and stalled at a light. I had the choke half on. It's been awhile. Anyway I pushed it home, argh!
Although it was rough in spots and had a charging problem, I decided to go over it with a fine toothed comb. I don't like to push the motorcycle home, it's silly, and that's what the gym is for.
The carbs leaked, the charging system didn't work, the brake lines were cracked, had a leaking seal in the trans, the owner didn't have any technical ability pertaining to repairs or maintenance, the battery was beat, and the starter was iffy.
Here's what I have done to it:
gas tank was acid washed and resealed on the inside
new yuasa battery
new fuel lines and filters
carbs rebuilt and synched
valves adjusted
new Metzler Lasertec tires
braided brake lines installed
engine oil and filter replaced
trans seal replaced and added new fluid
replaced the rubber boot on the clutch cable to keep water out of the transmission
splines were lubed
voltage regulater replaced
new BMW diode board
electric system checked
new valeo starter
new YSS Z-302 TRL Twin custom shock absorbers (springs chosen for my weight)
inspected
ready for pick-up tomorrow.
Work was done by a self-employed BMW mechanic with over 35 years experience (I trust him)
I have ridden it several times and it is strong and fun. I even ran it to the mechanics house (37 miles) with a non-working starter. Even though I had to push-start it, this time I made sure it didn't stall. I can't wait to get it tomorrow.
Hopefully, I can commute to the city for work once school starts.
Tired of posing and polishing, it's time to ride!
PS: Here's a picture of my 1966 Honda CB450 before I started restoring it 2 years ago:
new yuasa battery
valves adjusted
splines were lubed
new BMW diode board
new valeo starter
inspected
