alegerlotz
Member
A week or so ago I noticed that my 2016 RT wouldn't start in gear with the side stand down and the clutch pulled. The most likely culprit appeared to be the microswitches that are actuated by the clutch so I ordered the replacement microswitches - one part with 2 switches (for bikes with cruise control).
I swapped out the part and the issue is still the same. I even tested it with the switches plugged in but not installed in the clutch lever assembly to ensure that there was not an alignment issue or something not allowing them to operate properly when installed. No change.
Bike starts fine in Neutral with the side stand down or in gear with the side stand up, leading one to believe that the side stand switch is working properly.
What's my next thing to check?
