I'm just looking for ideas and options before I dive into providing different power options to my 2010 R1200RT. I've read the threads that I found on this forum and others but any additional ideas or help will be greatly appreciated.
Objectives (current & near future): Power 660 Zumo, AmpliRider, charging socket in tank bag used for both iPod and phone, XM radio power, and maybe a radar detector power connection.
Issues discovered so far: Need both steady 12V power and switched 12V power, hearing engine noise at high volume levels, Placement of all the stuff, and of course making it all look clean. Converted iPod files loaded on the Zumo don't sound nearly as good as what's on the iPod. Converting files is a bit of a PITA. Connecting the USB charger creates a lot of noise on the iPod. Normally charge when I am stopped only.
What I have so far: Zumo 660 directly wired to battery but with a switch in the tank bag, AmpliRider connected to the same switch, a charging socket directly wired to the battery (always hot) where I use a USB plug for both cell phone and iPod charging. Purchased but have not installed a noise filter - N-700 (it's kind of big but offers both passive & active filtration). Plan to buy the FuzeBlock to connect everything to.
Planning to do: N-700 to battery, Fuzeblock to N-700, run all wires under tupperware to front of bike (fork area). The Zumo is mounted on the fork with a Ram mount. Plan to run switched and unswitched power into a tank bag. I have an old RKA (very small size) that I am currently using for holding phone, iPod, manual switch.
Ok, finally for the questions...
1) is the N-700 only for the amp or the entire circuit?
2) are the expensive powered tankbags worth the cost (>$300!)?
3) what's a neat way to keep all the wires together?
4) does somebody make a nice waterproof way of disconnecting some of this items to make it possible to service other parts of the bike? I am thinking of taking this bike to the dealer for the next 3 years and don't want them to cut or bitch about all the wires under the seat. BTDT with my prior Honda.
5) Kind of related to #2 but is there a nice looking option for a tank bag? My current bag is perhaps a bit too small, run the wires into the zipper, and does not hold a standard size/folded map.
Sorry for being so long but I want to do it right the first time and I'm just back to BMW after going Honda 2 times, BMW 2 times, Honda 2 times, and now back to BMW.
Thanks in advance,
tsp
2010 R1200RT
Thanks in advance,
tsp
2010 R1200RT
