2009 R1200rt abs install and bleed
woody99
Member
I had the abs go bad, front brake lever was extremely hard, sent abs to Module Masters they said hydraulic was bad, so I picked up used abs, and now need instructions on how to bleed abs and system. There are several videos on you tube but none on 2009. Early year are different. Anyone have the proper procedure. Thanks Woody
Not sure if this is correct for your bike-
From the Hex/Cam tech library-
https://forums.bmwmoa.org/showthread.php?38825-HEXHEAD-Tech-R1200R-07-09-Brake-Fluid-Flush
Good luck.
