akbeemer
SURVIVOR
I am working on a friend’s 2007 RT with 63,000 miles on it. Performed brake bleed as done several times before on this model with no issues. Attached GS-911 and performed rear brake bleed test to actuate the ABS pump. Test seemed normal; pumped functioned for ten seconds and I depressed the pedal three times, each time for two seconds as it ran. After the test I depressed the pedal and after the second pump the pedal lost all resistance. It is not moving the pads at all and is not pumping any fluid. Went through the ABS test front and rear again. Pump runs and front brake seems to be functioning normally. I did have the swingarm/FD off the bike to replace a rubber boot.
I am stumped.
I am stumped.
