I went to start the bike today for a short spin prior to my pre-winter oil change and here is what happened...
1. Turned the key to the "on" position and the dash lights and head lights lit up as usual (including the blue hi-beam indicator)
2. Pushed the ignition button twice and nothing happened
3. Realized that the ignition switch above the right hand grip was flipped to the left which prevented the starter from activating
4. Flipped the ignition switch to the center / upright position...at that point the RID display lit up and the dash and headlights remained lit
5. Pressed the ignition button again and heard a "CLUNK!" mechanical sound and then everything went dark
Other circumstances:
A. Battery is 6 weeks old; was solid green on Battery Tender Jr before start attempt; was put back on Tender after failure and is now solid green again
B. Following the failure, turning the key to the start position illuminates NOTHING -- no dash lights, no headlights
C. I have LED aux/running lights installed...power to these lights is spliced from one of the aux power ports, controlled with a 5 amp fuse and a switch Velcroed under the dash. They draw 0.66 Amps per light @ 14.5v DC (see http://www.bikevis.com/motorcycle-cree-led-running-lights.html)
D. As I said, turning the key to start illuminates nothing, BUT when I switch on the aux lights I get a very quick on/off flashing, almost a strobe light pattern....with four of the "ons" being very dim and the fifth "on" being normal LED brightness. The pattern then repeats.
Any ideas on troubleshooting? I'm hoping that it's an issue with a fuse, but not sure how to test. In the meantime, by bike is stranded 25 miles from the BMW shop with the threat of snow looming...I really want to put the bike to bed healthy and with fresh oil!
Thanks!
Thanks!
