I am attempting to relocate the fuel filter on my 2000 R1100 RT. I read an article in the ibmwr tech pages by Rob Lentini concerning this modification. He did this procedure on an R model and this is where the problem arises. He relocated the filter to an area under the throttle body air intake and secured it using an Adel clamp attached to the brake line support, On the RT there isn't enough space in this area for a filter the size he recommends which is similar to the BMW oe filter. There is interference with the fairing mounting tab on the footrest bracket and it doesn't appear that the filter would clear the fairing when installed. I think I can mount the filter upstream under the tank by attaching the Adel clamp to the screw that attaches the fuel line and fuel pump wiring harness bracket to the bottom of the tank. In this position the filter sits about 1/2 inch above the cylinder. Is this too close to the cylinder due to heat? It also looks like there is room near the fuel pump plate between the fuel tank and the frame. Has anyone done this switch on an RT? Any advice would be helpful. I made an error saying this mod was done on an R model. It was an RS.
