1996 R1100RSL shaft/gear oil change torque
178339
1100RSL
Hi all
I am set to do a change on the gear oil in my shaft, and the instructions I downloaded are not specific on the torque needed for my moto.
For the Transmission Gear Oil change it mentions that a torque of 30Nm, but that some R1100 need a torque of 23Nm, which is it?
Also, under the Rear Wheel Drive Gear Oil change it mentions using 23Nm torque, with no difference for other types of R1100?
Does anybody know what type of R1100 I have or the torque needed for my moto? and why the different torque anyway?
thanks for any info on this
Ken
i'm gonna make a wild guess and go with "you have a RS model R1100"
all you need to know and more:
Oil-Head Specs ? torque values, clearances, capacities, etc.
Here is a torque chart for BMW oil heads
BMW Boxer Data
R1100RT / R1100RS / R1100GS / R1100R / R850R / R1100S
Unit or
Designation Data Spec.
Engine (incl. filter) 4 qt
Engine (w/out filter) 3.7 qt.
Gearbox fresh fill 1.1 qt.
change 0.85 qt.
Rear wheel drive
fresh fill 0.26 qt.
change 0.25 qt.
Valve clearance
measured cold, max. 35-deg C.
Intake 0.006 in.
Exhaust 0.012 in.
Spark plugs
Bosch FR5DTC
electrode gap 0.032 in.
limit of wear 0.04 in.
Engine Idle Speed 1000 +/- 150 rpm
CO value
without catalytic converter 1.5 +/- 0.5 Vol %
Cable adjustment - for increased cold starting speed
without cable junction < 0.04 in. play
with cable junction no backlash
Throttle (without cable junction)
gas cable (one piece) ca. 0.02 in. play
connecting cable no backlash
Throttle (with cable junction)
junction cable no backlash
Clutch cable adjustment
at lever 0.28 in.
wire cable at handle bar lever 0.48 in.
BMW Boxer Data Metric
Unit or
Engine (incl. filter) 3.75 liter
Engine (w/out filter) 3.5 liter
Gearbox fresh fill 1.0 liter
change 0.8 liter
Rear wheel drive (Differential)
fresh fill 0.25 liter
change 0.23 liter
Valve clearance
Intake 0.15 mm
Exhaust 0.30 mm
Spark plugs
Bosch FR5DTC
electrode gap 0.8 mm
limit of wear 1.0 mm
CO value
without cable junction < 1 mm play
gas cable (one piece) ca. 0.5 mm play
at lever 7.0 mm
wire cable at handle bar lever 12.0 mm
Tightening torques
These have been converted from Nm (Newton meters) to
the nearest 0.5 ft.lb. (foot pounds) by dividing Nm by 1.355.
Oil Filter 8 ft.lb
Engine oil drain plug 23.5 ft.lb.
Gearbox oil drain plug 17 ft.lb.
Rear wheel drive oil drain plug 17 ft.lb.
Locknut valve adjust 6 ft.lb.
Cylinder head cover 6 ft.lb.
Generator to bracket 14.5 ft.lb.
Tension multiple ribbed belt (Poly-V) 6 ft.lb.
Spark plugs 14.5 ft.lb.
Fuel tank to rear frame 16 ft.lb.
Fuel pump to tank 4.5 ft.lb.
Adjustable handle bars 14.5 ft.lb.
Quick release axle thread
(axial) 22 ft.lb.
Quick release axle clamp 16 ft.lb.
Brake caliper?front / rear 29.5 ft.lb.
Bearing bolt swingarm to gearbox/rear axle
(Locktite 2701) 110.5 ft.lb.
Idler bearing pinon on swinging arm on
gearbox/rear wheel drive
(Locktite 2701) 5 ft.lb.
Locknut (Locktite 2701) 77.5 ft.lb.
Rear wheel retaining studs 77.5 ft.lb.
Tube clips to air intake pipe 1.5 ft.lb.
Screw connect spring strut on control arm
(RS with side bearing) 31.5 ft.lb.
M 10 Screw 29.5 ft.lb.
Tighten cylinder head -- done only at 600 miles,
four nuts, do one nut at a time, loosen nut and
torque to 15 ft. lb., then turn nut an additional
180 degrees (called torsion angle)
Tightening torques
Metric
Oil filter 11 Nm
Engine oil drain plug 32 Nm
Gearbox oil drain plug 23 Nm
Rear wheel drive oil drain plug 23 Nm
Locknut valve adjust 8 Nm
Cylinder head cover 8 Nm
Generator to bracket 20 Nm
Tension multiple ripped belt
(Poly-V) 8 Nm
Spark plugs 20 Nm
Fuel tank to rear frame 22 Nm
Fuel pump to tank 6 Nm
Adjustable handle bars 20 Nm
(axial) 30 Nm
Quick release axle clamp 22 Nm
Brake caliper -- front / rear 40 Nm
Bearing bolt swingarm to gearbox / rear axle
(Locktite 2701 clean thread 150 Nm
(Locktite 2701) 7 Nm
clean thread 105 Nm
Rear wheel retaining studs 105 Nm
Tube clips to air intake pipe 2 Nm
8.8 screw 43 Nm
M 10 Screw 40 Nm
torque to 20 Nm., then turn nut an additional
Dali Meeow's additional data -- metric and English
Gap between lower rocker arm bearing carrier
and rocker arm
(manual pp.11.40) 0.05 - 0.40 mm
(Adjust to the minimum gap for
much quieter engine) .002 - .016 in.
Torque for T45 torx screws on the lower
rocker arm bearing carrier 18 Nm 13 ft.lb.
BMW used two different types of plugs on the transmission. One with a taper that uses the crush washer (owed torque) and one without the taper that uses a higher torque with no crush washer.
well, golleeee! and shazam, too.
thanks for the edumacating, Anton. :bow
Do you know the correct torque values for each design? Maybe the values I posted are for one of them?
Okay
It looks like this according to the pictures and information, if I pull off the plug and it is tapered and has a crush washer then I use 23Nm, without a crush washer I use 30Nm. Thanks a lot for that info!
Ken
