scottishsg
Hi there again!!
About to remove the nut holding the clutch housing to output shaft and examine the rear main seal.
I have two questions for you gurus!
1: How the heck do you stop the clutch housing from turning? I know on the K100 it has holes you can stick a hammer shaft into so the housing doesn't turn. What needs to be done with the K75? Seems odd they would not use the same housing when many other parts are shared.
2: Replacing the rear main seal. Is the BMW special tool needed for the install? I have read many people say that the seal needs to be curled backward? I've never heard of such a thing. Most rear mains are just installed to flush with the block and move on. Is this bike so different? If I am there, and the rear main looks ok, should I just replace anyway, or is it one of those, if you mess with it you may create a leak type deals.
Now I am on a roll......thought of a third question.
3: The gear position indicator on rear of gearbox seems to be cracked open. I have seen many pictures or others that are similar. Is this something that can be epoxy'd or should it be replaced also?
Thanks in advance for any input!!!
Stu
Stu
