My low-miles K100RS has newly adjusted valves, rebuilt fuel injectors, has no air leaks in the induction system (at last!), a functioning air mass sensor (near as I can tell) and a clean air filter. At idle, the engine runs roughly at 800 rpm +/- and the exhaust smells heavily of unburnt hydrocarbons. The air bleed screws (those brass items on the throttle bodies) don't seem to have any effect on the idle. Their o-rings are in good condition, yet playing round with the screws doesn't make a difference on the vacuum meter's reading or the idle. I'm wondering what the baseline setting of those screws should be. They are all presently set at one turn out from being fully seated.
The throttle butterfly valves themselves seem to be in synchronization and show no sign of ever being moved from the original factory setting.
TIA for any insights.
