I have the non adj pivot arm design my inard look different I'm gooin to change the fluid this week but Am going to look into the bolt you said thanks for the info!
I pointed out the wrong part for the seal. The push rod seal is in the back end of the input shaft. Item 16
non adjustable arm ? I did not know your modedl came with a non adjustable. live and learn
His bike is a 1984 the seal you point out is not use on this bike. They change after 9/80 on this. Only the boot keeps oil from coming out.
I looked at the parts book and I don't go along with that. I know I replace that seal when I had to rebuild my transmission on my 75 R90. The push rod and through our not the same as my 82 R65. I just had the transmisson out on the R65 to lube the splines there is no seal where the push rod goes on this and never has been. The transmission on my R65 has never been apart and I have had this bike since new and have close to 100,000 miles on this bike.
Don
Grease it up in there and replace the boot. Stops the drool.
