rocksternroll77
Bings have been rebuilt, cables and linkage all good - when it's warmed up it keeps revving up. I have to use the brakes to slow the motor back to idle. Not sure what to look at.
yes, clutch and brake - I'll check out the weights and springs - I have looked at everything else - I think
Were the O-rings around the butterfly shafts replaced as part of this rebuild? They can be an air leak source that can cause high idle as the bike warms up. A spray of starter fluid where these shafts exit the carb body can be a good diagnostic.
came here to type the same as greg did.
