…….. So I'm back to the carbs... and, to be honest, I have not a clue what I'm doing.
I started playing with the idle adjustment screw and the mixture screw by backing them all the way in and then adjusting with 90 degree turns on the way out. Is there a better method? Does anyone have any good resources? These are the Bing Slide type 53.
Anyways I feel like I'm on to it! Thank you in advanced.
Yes, I would definitely check the valves and also check the spark plugs. If the plugs are quickly becoming fouled, that is a strong indicator of too rich, possibly from the choke piston failure.
Although the R60/6 is surely not fast off the line, it can be a surprising peppy ride and a great deal of fun.
13 11 1 335 687 PISTON (from 08/74)
Is this mention of a "choke piston" a reference to the enricheners on the slide carbs?
I didn't think these slide carbs had chokes.
Sorry Paul. The /5 slide carbs had ticklers, but the later type 53 slide carbs do have a choke. The lever is mounted on the side of the airbox cover. It wasn't a guess. I own and ride a 1974 R60/6. The part number of the piston is in my prior reply.
A photo of my 74 R60/6 type 53 carb with choke lever and cable for the choke piston. BTW - the Max fiche says "from 8/74" for the piston, but my bike has a build date of June 1974.
Can you tell me what exactly is the rubber piston? I am looking at the wrong thing? See photo below.
This is the only rubber component I can find on on my choke.
Also I had the bike out yesterday, it started sluggish but then it started running quite fine. I'll keep exploring and tinkering until I can get it running perfectly.
Oh, so close. The rubber piece you circled is just a cover. Follow that cable, through the spring, all the way to the bottom of the cable. The bottom piece at the end of the cable is the piston. The bottom of that part should have black rubber on the bottom of it. If you go to the Max BMW parts fiche and use the part number for the piston, they have a photo of them.
