18 RTW fuel guage/range/tank
515PHOTO
Hi All,
I'm bonding with my new to me 2018 RT. 'How far on a tank' is always a first thing when I add one to the stable. My experience with this one is a bit perplexing. Fill tank and reset trip #1. Ride. Low fuel lite comes on. Keep riding. Last bar on fuel gauge vanishes. Switch to 'range' on dash info. 40 miles to go. Keep riding. range says 1 mile to go. trip #1 says 295. OK, I give, pull up to pump. 5.5 gallons bring it up into the very top. MOM says I have a 6.6 gallons of usable fuel. Quick math says I got 50.5 MPG. So, do you find the gauge, low fuel lite and range info to be WAY cautious? Did I have another gallon (50 miles more or less)? Thoughts and experience sought.
BTW--yes, I know, don't run it dry--don't run it low--bad for pump--bad for cat--bad for glass (Chinatown fans out there?)
Can't say for sure about the '18. My '06 consistently has about a gallon left when the distance-to-empty display reads zero. I consider that my "reserve", it has saved me several times.
I generally start looking for gas around 250 miles on the trip meter, or when the yellow low fuel light comes on. I never use the fuel gauge.
For me, the range is always a matter of riding style on any given ride, from a low of under 250 miles to just over 370 miles per tank with the instrument panel saying 10-zero range left. So I really don't bother to concern myself with the theoretical range except for planning fuel stops on trips. For touring I calculate on 270 miles per tank as very doable unless I expect to be running hard through the mountains and then I calculate 240.
Even then, it is only occasionally that I ride from fillup to fillup. I tend to stop once in the morning, at noon and perhaps once in the afternoon. I fillup and stretch and find the day goes much easier for me.
I know there is some range left after the bike says "0 miles to empty" but don't have any need or desire to find out how much is left unless it is an emergency. Modern engines use much finer and more detailed spray patterns, etc., on the fuel-injectors, to achieve the performance and emissions that they do. Sucking the very last bit of gas out of a tank typically means that you are picking up the largest pieces of sediment and crude that are in there and running them through your fuel system. This typically won't cause any issues, but it is opening the door to them and can create a needless problem so I leave that till it might be necessary. YMMV
My 18RTW gets about 300 miles to 0 miles left. It shows no bars on the fuel gauge a few miles before that. I have only been able to put about 5.6 gallons in the tank at this point. It is my belief that the low fuel warning happens about 1 gallon to early and that the fuel gauge is also showing a lower reading than actual fuel left. I have talked to my dealer about this when I took it in for service. The service person had it checked. His response was that there were no error codes and that maybe that could change the sensor at a later date if I wanted them to. I will probably follow up on this next year while it is still under warranty.
Same thing here with my 18RT. I can run it down to zero miles fill it up and the tank will take about 5.5 gallons. One time I took a about a quart of gas with me and ran it to -20 miles . Still didn't run out of gas. Talked to local service mgr at dealer he said they could look into it but most likely would come up with anything. After 10K on the the bike I just play it by ear. No problems so far.
I think we should contact BMW collectively about this. It may get a response that way. Is there an email address that we could use for this?
I don't understand how this is a real problem. If the results are consistent then you know what to expect and plan with this in mind.
This is a real problem because it is inconsistent with the owners manual which states that the low fuel warning light will come on when there is approximately 4 liters left in the tank. When in actuality there is more like 8 liters left in the tank. Also, anybody riding the bike that is not familiar with the fuel gauge inaccuracy will be stopping early to fill the tank. Quite simply BMW should have an accurate fuel gauge.
The (US) manual states:
Usable fuel quantity - Approx 6.6 US gal (Approx 25 l)
Reserve fuel quantity - Approx. 1.1 US (Approx 4 l)
It is slightly confusing in how its worded, but from experience of those who have posted it sounds like the total is 6.6 gal, but the gauge goes against all but the reserve, so 5.5 gal.
It sounds to me like the system is telling folks "miles to reserve" rather than miles to being a pedestrian.
Never got this concerned as the F800GS is the first bike I ever had with an actual fuel gauge. I don’t consider it really possible to be 100% accurate. 160 miles - look for gas using the trip odometer......I have faith in that.
I don’t know how accurate the fuel gauge is in any of my 4 wheel vehicles either........using the trip odometer as a reference on 4 wheels as well. :dunno
I have never, ever, had a fuel gauge that was completely accurate. Almost every one I've ever had was conservative in a way, and not so conservative in another way. Every one has shown empty with fuel left. At the same time most have shown the first half of the tank being used more slowly than the bottom half of the tank. And often that last quarter of a tank seems to be going away fast enough to have gas dripping on the roadway.
The best I can do is get used to the behavior, and hope I remember which is the car and which is the pickup and which is my bike. Actually the most accurate full to empty is on my G310GS.
Or as Voni says out here in West Texas and the Great Plains generally, "Gas early and often." We do not live and ride where there is a Stop & Rob on every corner, or even in every little town. :)
When traveling across country on a 20141 RT I am lucky h to get 230 miles. I usually need to pee by then. I have had to push it when I misjudged the next gas station. There are still places in this country where the gas stops are few and far between. So I have learned to get it when I can. Wasting ten minutes is better than wasting half a day. If you ride your bike enough you get a feel for when it needs fuel. All I care is the gauge works consistently. I will learn the nuances.
