shoot2miss
Member
Just picked up a set of spoked rims. I'll now have 80/20's on my cast rims, and 40/60's on my spoked, making for quick changes. I've already mounted the Shinko 804 and 805, but need an ABS sensor ring for the front. I found one (correct BMW part #) on eBay, so it should arrive soon. When I look at the torque specs for attaching the rotor the rim, it indicates that the screws should be replaced, and not re-used. At 24nm are the screws really being stressed enough that they need replacement, or is that just BMW's lawyers talking? If they need replacing, will the local Ace Hardware's stock suffice? Would you use thread locker on these? Thanks
