after much anticipation I finally swapped my 2000 RT for a (new) 2006 RT; for obvious reasons there is no bike riding in ND this time of the year. After trailering the new bike home I plugged the BMW gel charger into the onboard socket, just as I had done on by 00 model after getting a gel battery; the initial indication was the same (solid red) indicating the battery was being charged; upon returning about six hour later the battery was fully charged but the indication was a blinking red light meaning "battery not connected properly." On the prior bike it would indicate green meaning the charge was complete and it was entering the "float' stage. I have let the battery run down a bit (lights on) to retest the system. It again went from solid red to blinking red and did charge the battery; any opinions on the diffenence beween the systems; I was very happy with the "float" mode while keeping the battery charged over the long winter months and do not want to harm the battery or the electronics. I note that the charger puts out a max of 1.25amps which is well within the tolerance of the new system . Thanks....wj
