jgsmith
I have a strange problem. Some might say I have several, but only one that applies to this forum.
Here goes:
I have a 2006 R1200RT with 60,000 miles (100,000kms), owned since new, and all service done by the dealer with the exception of some oil changes. 2 years ago, when the bike was 4 years old and with ~40,000 miles, it started to have an intermittent stalling problem. I have had the dealer look at it twice, and the only conclusion has been, "we can't reproduce it, or find anything wrong, but happy to keep spending your money if you want". This only happens when the bike is thoroughly warmed up, and does not always happen. While I am riding, there is no sign of an issue. Good response, good power. I pull to a stop, release the throttle, and the bike idles very low and rough, then cuts out. I start it back up, which can take 2-3 tries, and it will only stay running if i give it some throttle. Doesn't take much, just enough to get the idle up and its fine. Once this happens, I can never completely let off the throttle, or it will stall. This makes for extremely hairy riding in traffic. If I stop the bike and let it sit for a bit, the problem will usually go away until the bike is thoroughly warmed up again. As an example, last summer I rode from Toronto to the Redmond rally. I had no problems at all for the first 10 days, then I had the problem every day, usually starting mid-late morning, and continuing until I stopped for the day. After 4-5 days, it went away. It feels exactly as though the idle just needs to be increased a bit, but I am told there is no such thing on the RT. Its all handled by the software.
Here is what I have done so far:
Spark plugs: Been through several sets, no change
Cables: I have looked and so has the dealer. All seems ok.
Electrical connections: I have looked and so has the dealer. All seems ok.
Valve adjustments: Been through several, no change
Throttle reset: Done, no change
Stepper motor rest using the GS-911: No change
Any thoughts, or do I use this as an excuse to get a new GS?
Jim
Jim
