I am sure that I have a bad LH turn signal switch. Has anyone had success repairing the combination switch assembly by just replacing the small switch? It appears that the cost of the assembly is over $400.00
I had a problem with mine on my 05 RT. I removed the whole assembly from the handle bar and sprayed it (heavily) with contact cleaner, then blew it out with light air pressure. The switch is working fine now. Every now and then I spray contact cleaner in the openings that I can see without pulling the assembly and let it air dry.
I ended up replacing the entire unit. The hardest part was moving the gas tank out of the way so that I could get at the plug. Of course on the way home with my new part, I stopped and filled the gas tank. Live and learn, now I have a can of gas for my lawn mower
