Sliders for the motorcycle lift
Thanks for the information on the Harbor Freight coupon in Cycle World. I used that and got a lift for my Christmas gift. Today, I finally put the bike on it. The center stand sits on the removable rear plate and the front tire is only partially in the wheel vise.
Please post some more information on your "slider" modification. A picture would be great.
Also - I need some advice on anchoring the bike to the lift. The K100LT is fully faired and any anchor point on the handle bars causes the strap to be tight across an edge of the fairing. Works ok but will probably wear paint away after a few uses.
2) When you put the bike on the center stand, it pulls back so far you can't lock the front wheel. I made a slider so that I can put in on the stand, then roll it up to lock the front wheel. I just used those Teflon furniture slides.
-Robo
