Results 1 to 9 of 9
Thread: 1985 K100RS. Only luck is bad luck it seems!
    Jan 2020
    Calgary, Alberta, Canada
    Bought a used rad from James Sherlock Oct 22, 2020 with a 6 month warranty. Had it pressure checked that November with no problems. Just fired the bike up about 3 weeks ago to make sure rebuilt water pump and this rad didn't leak and they didn't. Got the bike hot and cycled the cooling fan a couple of times. Everything was tickety-boo. Beautiful day today so I was heading out for a ride. As I just checked the valves I did a preliminary run-up to make sure the valve cover wasn't leaking. After shutting the bike off I noticed a pool of coolant on the garage floor about the size of the palm of my hand. After removing some of the body panels I found the leak was coming from the tank crimping just by the thermostat cover. AHHHHHHHHHHH! The good news? It has a 6 month warranty which expires April 22. Hopefully they honour it. I have contacted them. Just freaking unbelievable!
    Jan 2020
    Drake at Kbike parts came through for me with a rad.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Good to hear. I have a couple but wasnít sure of their condition as they were given to me so didnít want to offer up another problem rad. Is that tape on your coolant hose, coming through your crank case cover? Looking forward to hearing about you back on the road soon.
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    Jan 2020
    Quote Originally Posted by 6322 View Post
    There isn't anything on that lower hose. Not sure what you're seeing.
    Mar 2012
    Riggins, ID
    Quote Originally Posted by mcmlcccvrs View Post
    Must be my old eyes.😵
    Jan 2020
    Has anyone ever considered/attempted something like JB Weld for fixing leaks like this? It's by no means severe, so........ While I do have another rad coming from Drake Smith, I'd like to have a go at trying to stop this leak. Nothing to lose really.
    And on a not-so-happy note, it would appear James Sherlock in the U.K. is not going to honor his 6 month warranty on this rad. I'll refrain from any negative comments here as I don't want to run the risk of being banned from a forum that has been extremely helpful and useful to me. Not very happy with this guy.
    Nick Kennedy
    Telluride Colorado
    JB Weld is certainly a option.
    People have fixed alot of stuff using it. It's been around along time. I bet it would work.
    I've got a unopened package of Gorilla Glue epoxy on my workbench I'm looking forward to using soon on something.
    The Gorilla Glue line of products is good stuff.
    Good Luck
    Nick
    1990 K 75 RT
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    45 years ago on my Dodge Dart I fixed a similar leak with a stop leak additive, Bars Leak I think it was called. I was pleasantly surprised it worked but had no idea if it gummed up anything else. Never had any issue with the car for a few more years before I traded it in though.
    I am not implying you should try this. Just remembering when.
    Jan 2020
    And the bad luck continues. This is the rad I got from Drake Smith at Kbike parts.com two days ago. I did get a clear understanding from him that if I started up the bike and it leaked he would refund my money. Well, that is pretty much what happened. It only took a couple of minutes for this to appear.
    More heartbroken than anything else as riding season is here with no prospects on a good rad.
  1. BAD Luck:(. R1200GS
    By Polarbear in forum Hexheads/Camheads
    Last Post: 07-14-2013, 03:14 PM
  2. Luck ?
    By patiodadio in forum Campfire
    Last Post: 04-16-2011, 02:48 PM
  3. Am I out of luck? Looks like Clymer says so...
    By Zagando in forum Flying Brick K-bikes
    Last Post: 06-20-2010, 04:23 AM
  4. Wish me luck with KRS SE rebuild
    By beemerguru in forum Flying Brick K-bikes
    Last Post: 02-14-2010, 01:15 AM
  5. Just my luck
    By beeryboats in forum Oilheads
    Last Post: 07-24-2008, 05:12 PM
