The Clymer manual outlines a test procedure whereby an off-idle speed voltage is taken from the B+ terminal of the diode board and the D+ terminal of the alternator brush assembly and compared to the off-idle speed voltage from the D+ terminal on the diode board and ground. My understanding is that the D+ terminal on the diode board is on the backside where the three alternator wires attach. How to you access the D+ terminal of the board while the engine is running???
