jackdannenberg
I have adjusted the valves of a lot of overhead cam motorcycles and have never seen marks like that or any other indication of cam wear. Camshafts are just not wear items. Because there are several reports of cam wear issues on the water cooled boxers I would be pushing for a warranty cam replacement. The fact that the valve clearances are ok does not surprise me. Valve clearance is measured on the heel of the cam. There is no metal to metal contact under pressure on that part of the cam. This is a quality control issue and BMW should be replacing worn cams even if out of the warranty period if there is evidence of proper oil changes. I have a 2016 GS and I will be doing an oil analysis at every other oil change because of this issue and the fact that the local dealer does not offer any type of extended warranty.
