Just don't use the "Marketplace" on the home page. It will send you to the old one.
Go to the top of the page and click bmwmoa.org
Resources > Marketplace
You will end up in the old Marketplace
Been that way for a very long time.
Hello,
After I login from home page > Resources > Marketplace, I Continue on "post my picture" (which I can't do), and I then skip the next step. This puts me into an end-less loop on the "We Are Building Your New Community!" page. I presume that this is the OLD marketplace. Maybe I am mistaken.
The only way I can get to the new Marketplace, and use it, is by using a bookmark from the forum after I login. But, not from the home page > Resources > Marketplace. Even if I login on the forum, and go to home page > Resources > Marketplace, I get locked at the "We Are Building Your New Community!" page.
I would have to presume that other members are getting the same issue I am, and just leaving.
From being here, logged into the forum, tapping the Marketplace button, I am directly led to this-
Omega Man - I presume you are not a programmer, so I'll take your post with a grain of salt. The parameters you have with your login are different then the ones I have, so you can't take a simplistic view of the problem.
Just give the problem to your programmer. I'm sure he can solve it in a couple of minutes.
No member should be frustrated by this. Hasn't the MOA lost enough members?
I have always gone to the marketplace from the header bar on the forum.
I just tried to go to he marketplace from the MOA home page > resources > marketplace and got the same run around that the OP and 23217 got. Not good!
23217s presumption is probably right on. This needs to be fixed.
